A for-loop to iterate over ring
How can I create a for-loop in LabVIEW to iterate over a Ring control, similar to using the "Enum to Array of Enums.vi" function for an Enum?
Message 1 of 11
(619 Views)
You can't.  (Unless your ring is strictly typedef'd.  See below.)
In an enum, the strings and values are part of the data type; and therefore the values and strings are in the wire type and are accessible to anything that the wire connects to.
However with a ring, the strings and values exist only in the controls, indicators, and constants, they are not in the wires; the data type of the wire is just an integer.  (It is because the strings are not part of the data type that you can change them at run time.)
If your ring is strictly typedef'd, you could use Data Type Parsing to find the path to the typedef, then extract the strings and values from there.
Message 2 of 11
(590 Views)
Do you want to iterate over the values of the Ring or the string as well?
Santhosh
Soliton Technologies
Message 3 of 11
(579 Views)
Can you show me an example? I don't see how this can be done.
Message 4 of 11
(571 Views)
iterate over the items.
Message 5 of 11
(566 Views)
Do you just want to loop over the values in the ring?
Jim
Message 6 of 11
(561 Views)
Thanks, but I need an implementation of this functionality in Constant Ring
Message 7 of 11
(550 Views)
Accepted by maxnoder1995
Here.
One very important caveat: If you make changes to a strict typedef of a ring, then apply those changes, by default, the changes will only be applied to controls and indicators, not to constants.  However there is an undocumented property of ring constants called "Act as Strict Typdef Constant" which, when set, will have applied changes propagate to that constant.  I have set that property to TRUE in the constant in "My Ring Item Iterator.vi".
Message 8 of 11
(543 Views)
Rings can have non-sequential values and I assume you want to iterate over the values, not item names.
Just get the "string and values" property an iterate over the elements of the array. Inside the loop, unbundle what you need.
Message 9 of 11
(525 Views)
PERFECT! Thank you very much! By the way question, Why not close the reference of the VI right after the property node that brings the reference of the Panel? Why close the references at the end of the program?
Message 10 of 11
(509 Views)
