03-16-2023 08:53 AM
Hello!
I am facing a difficulty in detection of the AM wave in the received side. The received wave contains full of noise and even though by changing the values of frequency, amplitude, number of samples the problem still exists.
I tried to filter the signal using a Chebyshev filter for bandpass and Butterworth filter for lowpass. They're also coming with so much of noise. I am adding my receiver design herewith.
03-16-2023 10:30 AM
So the difficulty is that there is too much noise. Where does the signal come from? What hardware do you use? How do you process it? so many questions!
03-16-2023 10:01 PM
@Varun1103 wrote:
Hello!
No matter what is going on, you will want to reduce as much noise as possible in the analog domain, there is no good reason to digitize noise.
03-17-2023 03:52 AM
Can you outline exactly the process you are using to "demodulate" your AM signal.
I presume the first step is to multiply with the carrier signal, right? The frequency you're interested in demodulating? This is actually the step which allows lock-ins to remove so much noise. Filtering comes afterwards.
03-17-2023 02:14 PM - edited 03-17-2023 02:15 PM
What's your AM transmitter and what's your AM receiver?
Without this information all I can tell you to do is try harder.
