AND operation on two signals
(2,513 Views)
You are going to have to give more details.  What are you inputs?  What do you expect out?  What have you tried already?  Why such a large image that is 90% white?
GCentral
(2,511 Views)
Let me google that for you...
Boolean
Signals
(2,506 Views)
i am having three pulse signals 1kHz,2kHz and 100Hz.
during the positive cycle of 100Hz pulse, i need the 1kHz pulse to excite an LED.
during the negative cycle of 100Hz pulse, i  need the 2kHz pulse to excite another LED.
(2,477 Views)
Can you already read the signals? The LabVIEW code will look just like the image you posted if that is what you are asking.
LabVIEW 2012
(2,475 Views)
HI,
As previous posters have said, you can create exactly this setup in labview - it'll look just like your diagram. Use the Boolean primitives located in Functions>>Programming>>Boolean:
-CC
"If anyone needs me, I'll be in the Angry Dome!"
(2,443 Views)
