07-12-2012 02:24 PM
Help me out to simulate the below operation in labview
07-12-2012 02:31 PM
You are going to have to give more details. What are you inputs? What do you expect out? What have you tried already? Why such a large image that is 90% white?
07-12-2012 03:05 PM - edited 07-12-2012 03:07 PM
07-13-2012 12:53 PM
i am having three pulse signals 1kHz,2kHz and 100Hz.
during the positive cycle of 100Hz pulse, i need the 1kHz pulse to excite an LED.
during the negative cycle of 100Hz pulse, i need the 2kHz pulse to excite another LED.
07-13-2012 12:58 PM
Can you already read the signals? The LabVIEW code will look just like the image you posted if that is what you are asking.
07-20-2012 07:40 AM
HI,
As previous posters have said, you can create exactly this setup in labview - it'll look just like your diagram. Use the Boolean primitives located in Functions>>Programming>>Boolean:
-CC
