Access class private data that is an array of clusters
I have a class private data that has an array of clusters. I need to set the data in a class method. I tried to use the array bundle by name but that did not work. There is a step to access the array element that I must be missing. The class private data element is an array is Test, which is a cluster.
This is a snippet from the block diagram. How do I access the Test cluster from the array? Any help appreciated.
(3,428 Views)
It seems like you managed to set the data, now you need to get it back to the class, with Replace array subset and Bundle by name.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,418 Views)
I added 2 new VIs "VI for Data member access" to write and read the data. Still not able to write to the class member array cluster data.
(3,401 Views)
Accepted by topic author davidhi
What do you have in write element of test.vi?
It should be unbundle class, replace subset (make sure array has enough size, otherwise - build array), then bundle back into class.
Read is just unbundle - index array.
PS index better be blue to track rounding errors.
(3,385 Views)
Just to elaborate a bit here on Alex's sage advice:
It won't do to just add an explicit conversion or rounding function here.  Make sure that whatever is calculating this index makes the right integer choice when it comes to non-integer values.  (Which may, of course, turn out to be a simple rounding function - but then at least you've thought it through and decided it's okay to round.)
Bill
CLD
(Mid-Level minion.)
(3,376 Views)
