Acquire analog signal using cRIO Scan Interface
Hello All,
I'm new to LabVIEW and I'm trying to perform a very simple task (at least I thought so), acquire a sine wave - 1KHz, 2Vpp, from signal generator using cRIO-9035 in Scan Interface mode with NI-9205, LabVIEW 2017 on Windows 10.
My program (also attached):
But the signal that I see is not 1kHz, it's much lower. Clearly I'm missing something.
In addition, when observing the AI channel in NI Distributed System Manager, same thing - the signal is much slower than the generated frequency.
Any assistance will be much appreciated.
Thanks.
(3,098 Views)
Accepted by IG.B
What is the scan engine speed? Is it picking up samples quicker than 1Khz
(3,096 Views)
You can't really push the scan engine to be faster than 1kHz.  So based on Nyquist, you can only see a signal that is up to 500Hz.  You probably really want to sample at 10kHz in order to get a good representation of your signal.  Therefore, you will need to use the FPGA to read the signal and use a DMA FIFO to send the data to the RT system.
GCentral
(3,066 Views)
I totally forgot about it...
Thanks for pointing out the basics!
But I still can't figure out how to view the AI channel in Distributed System Manager program...
(3,064 Views)
Tools->Distribution System Manager
Select your cRio->Expand
Click on which mod's output you want to see and expand. See output by clicking on AI0, AI1, etc.
(3,050 Views)
