Add Columns of Array
I'm having somewhat of an elementary problem here...
I start with a 1D Waveform from a DAQ request, which contains ~22 columns of data corresponding to different measurements. I wanted to take the first 20 columns of this data and add the "column vectors" (i.e. each measurement) to get a 1D array (the summation of the first 22 1D arrays/measurements/vectors). The logical way to do this, it seems, is by indexing the waveform with a for loop, converting to DBL, and then adding each column with a shift register.
1D Waveform --> For loop (indexed) --> Get Waveform Components to get DBL Array for the index column --> Go to "add" block
And then by using a shift register I add each index column.
However, I get no output once the for loop finishes.
Any ideas? Examples are JPEGs/PNGs please!
Message 1 of 47
(4,815 Views)
This might help you out
Message 2 of 47
(4,801 Views)
Please attach your code.
Message 3 of 47
(4,796 Views)
Thank you both for the help.
I always thought an indexer of a for loop indexes columns, not rows. But in Fernando's example it seems like rows are being index, then summed.
Why, for example, is the attached not working?
Message 4 of 47
(4,754 Views)
array a = [1,2,3]
array b = [1,2,3,4,5]
in LV a+b = [2,4,6].
In your case you are adding [] to [n, n+1, n+2]. You cannot do this.
In this situation, you should have used the "build array" function, right clicked it, and selected "concatenate inputs."
Message 5 of 47
(4,748 Views)
You can do this, it just wont work the way you want 😉
Message 6 of 47
(4,745 Views)
Accepted by ap8888
I'm a big fan of doing things the easy way.
"Should be" isn't "Is" -Jay
Message 7 of 47
(4,723 Views)
So to verify, the attached two blocks perform the exact same summing (of columns) operation?
Message 8 of 47
(4,693 Views)
Summed would have the same result in either case- Which is quicker to sling?  What if you wanted to really boost the array size and started bogging down a CPU core?  Which for loop is parallelizable?
One.jpg on all counts.
Now wait for Altenbach,  He'll chime in with a perfomance enhancement
Hold it..... I'm channelling.
For even better perfomance, since the size of the output array can be determined.  Initiallize an array of the required size and replace index[i] inside the loop.  This prevents re-allocating the array buffer multiple times as the array size grows"
Message 9 of 47
(4,676 Views)
Hi
I try to find the number of ones in array at the end but it is not working.
Could some one help?
Message 10 of 47
(4,403 Views)
