03-27-2015 11:36 AM
03-27-2015 01:08 PM
Hi GerdW Knight of the NI
it is BER rate with help of hamming code.
Thank You for your help.
03-27-2015 01:17 PM
fate,
Try this
03-27-2015 01:19 PM
You don't have the same function in your VI that you have in your picture.
The picture uses Boolean to (0,1). Your VI used Boolean Array to Number..
03-27-2015 01:28 PM
Griff22 , what is that? It is not working? Are you kidding me?
to the others I should say that it is with boolean to numebr or boolean to 0 or 1 , it is not working.
hope there are some professional nights in here.
03-27-2015 01:32 PM - edited 03-27-2015 01:47 PM
Okay if you are trying to find out the error between the 2 arrays, start with the arrays the same size.
Try this Vi Just change the numbers in the array and check the results. Answers are in percentage.
( by the way for someone who is asking for help you could be a little nicer.)
Have a nice day.
03-27-2015 01:44 PM
BER IS 0 for two examples in picture. BER must be less than 1.
03-27-2015 01:50 PM
Ok, sorry.
I can not open your design, My version of labview is lower. Could you please send me the picture? I want even when 2 arrays not in same size, is working in this way?
03-27-2015 02:27 PM
try this. It should take into account the diffeerent size arrays, and output a false for the ones that are "Extra" in either array. It also will divide by the larger of the 2 arrays.
03-27-2015 02:52 PM
I do not have Labview 2014. What is the name of your two new blocks. I do not know their names.
Thank you
