Adding Decorations
What file types work best as decorations and can I add them to the decorations pallet ?
Message 1 of 11
(3,777 Views)
Hi ggress1,
you can put images on your front panel. Use BMP, PNG; JPG formats.
And no, you can't put them to your decorations palette…
Message 2 of 11
(3,721 Views)
Drawing these in a program like Inkscape (free) has its advantages- these vector images can be rescaled on the front panel without becoming blocky.
Message 3 of 11
(3,709 Views)
What vector format is compatible with LabVIEW, please? because, if oen exports/saves them as bitmaps (png, jpeg, or bmp), they lose their scalability.
Message 4 of 11
(3,670 Views)
.svg I think - whatever Inkscape spits out as default. You've got me questioning if I Imagined this experiment now - you'll have to give it a whirl and please let us know the result. I'm pretty sure I imported an svg as part of a custom control and it worked. Decorations I'm not so sure.
Message 5 of 11
(3,653 Views)
No luck with SVG. One should create a large enough PNG (best bitmap output for originally vector images) to avoid pixellation at scaling.
Message 6 of 11
(3,646 Views)
Sorry for the misinfo... the old melon isn't what it used to be.
Message 7 of 11
(3,638 Views)
LabVIEW supports a vector format of WMF.
Message 8 of 11
(3,621 Views)
Oh and you can put decorations on your palette, you just need to have it be on a VI, and then set that VI to be on the palette and configured to be merged when dropped.  This will then drop the front panel of that VI which would just be your decoration.  VIPM supports this and so does editing the palette through the Tools >> Advanced >> Edit Palette Set.
Message 9 of 11
(3,615 Views)
I have decoration on a VI. when I try to build package the VI automatically goes to Functions Palette and not Controls... How can I make it appear in Controls Palette?
Message 10 of 11
(187 Views)
