Aditionner string hexadecimal
Bonjour,
Je suis débutant dans Labview.
Comment est-ce que pourrais-je additionner à une valeur fixe(hexa) 2 valeur hexadecimal par 2 bytes?
exemple: je dois additioner F424 à 277 donc F4 + 24 + 277.
277 est une constante string.
Merci.
Message 1 of 9
(3,414 Views)
Welcome Aleksandar,
could you please rephrase your question in English as this is the English forum?
There is a sub-forum just for French (speaking) people
Message 2 of 9
(3,391 Views)
Sorry,
I need to add a hexadecimal string. How can i add 3 different hexadecimal string?
Exemple: i want to do   277+F4+24 and i need a answer in string.
Message 3 of 9
(3,385 Views)
Hi Aleksandar,
when you want to concatenate strings you should use the ConcatenateStrings function…
Message 4 of 9
(3,380 Views)
Use "Hexidecimal string to number" for each of the numbers you need to add.
Add them together.
Use "Number to Hexidecimal string" to get answer back into string.
Message 5 of 9
(3,367 Views)
@AleksandarG wrote:
Sorry,
What exactly do you mean by Add?  What would you expect as the result from your example?
GCentral
Message 6 of 9
(3,361 Views)
Hi Aleksandar,
the solution from deceased should work fine.
I made you a little example VI with the functions deceased described.
Stefan
Message 7 of 9
(3,327 Views)
Thank you, you really helped me.
Message 8 of 9
(3,293 Views)
Prevent diagram clutter by using array operations instead. 😄
Message 9 of 9
(3,288 Views)
