After compile fron panel image changed , how can i fix it ?
I have version 7.1 the problem is :
After compile software and try to open it on another computer (the exe file ),
there is  an image drift on front panel  (on several items)
so it is not possible to work with software,
If i open the exe file in the computer it was compiled then software works fine,
What shall i do ?
DoranSmiley Surprised
(3,069 Views)
Assuming that this is a Windows computer, check the font setting on the display control panel (apperance tab) of the new computer. Make sure it is set to "normal" and not e.g. to ""large".
Check also the following link:
(3,061 Views)
HI ,
The font was normal ( i am working with windows) , but i changed  the DPI setting to normal ( start => setting=> control panel=>display=>advanced)
and it looks better ( look on the attachment),
But still there is a little shift between controls as can be see in attachment 2 ,
As workarounfd i can perform tunning on the master computer , but i am afraid i will have to do this tunning
for each computer , and i think there are at least 10 .
So thanks again Smiley Wink
(3,047 Views)
