Agilent 4294 LV 7.1 program doesn't work in LV2016
Hi All,
I am trying to run a VI written in LV 7.1 in LV2016. Program seem to go through initialization steps and get stuck in a loop. After some debugging I realized a message box doesn't pop up. If I copy this message box to a new VI it works. Can someone point me in the right direction? I LV knowlege is beginner level. Copy of the main VI attached.
(2,737 Views)
First of all, there is no reason that this code should take up a block diagram this size.  I'm guessing you inherited this code from another programmer but, upon first glance, this program looks like it could be shrunk down to fit on a 1024x768 screen without scrolling, if state machines, subVIs and event structures are used properly.  It might be worth undertaking that task, if you are up for it and are willing to learn about proper program architecture.  I'm sure you could get a lot of help from people on this forum if you decide to do that.
So is the code getting stuck in the first initialization loop with the dialogs about file locations and overwrite permissions, etc or somewhere else?
aputman
Heads up! NI has moved LabVIEW to a mandatory SaaS subscription policy, along with a big price increase. Make your voice heard.
(2,710 Views)
