Aircraft environmental control system
Using LabVIEW design a cabin temperature control system that maintains the temperature from 18-30 deg C inside the cabin while using 400 deg C bleed air from HP compressor as inlet air source.
• Sensor Selection: Air Duct Temperature Sensors
DAQ Setup:
  • Choose a DAQ system that can handle the types of sensors installed, considering factors such as number of channels, sampling rates, and resolution.
  • Use LabVIEW to configure each sensor channel, setting appropriate sampling rates and calibration data for accurate measurements.
  • Implement real-time data acquisition using LabVIEW's DAQmx libraries, which provide functions to read and preprocess sensor data effectively.
  • Create a user-friendly dashboard in LabVIEW's front panel to display real-time data and analysis results. This can include graphs, gauges, and indicators that alert users to potential issues.
(437 Views)
DAQ Setup:
  • Create a user-friendly dashboard in LabVIEW's front panel to display real-time data and analysis results. This can include graphs, gauges, and indicators that alert users to potential issues.IMG_3167.png
(415 Views)
... and your question is?
Santhosh
Soliton Technologies
(434 Views)
Useful to read before submitting homework here :
How to ask questions
(420 Views)
Duplicate topic
https://forums.ni.com/t5/LabVIEW/Cockpit-temperature-control-system/td-p/4379608
Santhosh
(411 Views)
