Append number to worksheet name if current name exist
@Altenbach
http://forums.ni.com/t5/LabVIEW/how-to-display-duplicate-strings-in-1d-string-array/td-p/2797222
The code is in the thread marked solution. (Obviously Smiley LOL)
mcduff
Message 11 of 16
(845 Views)
@mcduff wrote:
@altenbach
Thanks. (Yes, that was just a 2 minute effort. 😮 But as I said in that post "Note that there are significantly more efficient ways to do all this, but the current code is sufficient for small arrays." :D)
Message 12 of 16
(843 Views)
@Altenbach
For my purposes, I had no more than an eight element array of names for DAQmx channels that the user could enter. Your solution worked perfectly to find any duplicates in the name array. It was late Sunday and I was trying to finish up, so at that point the code was sufficiently efficient.
mcduff
Message 13 of 16
(840 Views)
I did try your suggestions (see attached code under the "Check Name" state).
Thanks.
Message 14 of 16
(829 Views)
@hiNI wrote:
I did try your suggestions (see attached code under the "Check Name" state). .
It always helps to quote relevant parts of the post you are replying to (as I just did! 😄 Notice the [Quote] button in the upper right of the edit window?). Nobody knows what "your suggestion" was from reading your post..
Message 15 of 16
(824 Views)
Sincerest apologies...
The "your suggestions" that I was referring to were the comments by Minions (in his attached code snippet) and also by Bob_Schor.
hiNi
Message 16 of 16
(808 Views)
