Application builder error
I am trying to build a stand alone exe file from a Labview VI using the application builder.
I get the following error message:
"Error 8 occurred at AB_EXE.lvclass:Build.vi -> AB_Build.lvclass:Build_from_Wizard.vi -> AB_UI_Frmwk_Build.lvclass:Build.vi -> AB_UI_FRAMEWORK.vi -> AB_Create_Build_Application.vi -> EBUIP_Global_OnCommand.vi -> EBUIP_Global_OnCommand.vi.ProxyCaller
Possible reason(s):
LabVIEW:  File permission error. You do not have the correct permissions for the file.
NI-488:  DMA hardware error detected."
Any idea? thanks
(2,226 Views)
Accepted by DavideB
Do you have an explorer open with the target folder or something? This typically happens when the build process can't clear the target folder before building. You can e.g. delete it yourself to see if it helps. (one time i actually had to change the target folder just to get it to build)
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,211 Views)
Thanks!
(2,157 Views)
