Arduino LINX communication
I use Arduino to read voltage and current reading  using LINX but the readings are varying speedily can can anyone suggest to get smooth sine wave ?  image.pngimage.png
(591 Views)
Accepted by Gappiya
Arduinos are slow and LINX makes then even slower.
  1. What is the frequency of the sine wave you are trying to capture with the Arduino?
  2. What is the "Loop Rate" being reported
You are trying to make a digitizer and the "loop rate" being reported is your actual digital sampling rate.
Take a look at this Acquiring an Analog Signal: Bandwidth, Nyquist Sampling Theorem, and Aliasing
Especially the section on Sample Rate
=== Engineer Ambiguously ===
(562 Views)
