Are there any Octal to ASCII string converter?
So you are starting with a string that contains plain text that are numbers representing octal numbers?  Just use the Scan From String as you have already been told to make a U8 integer.  Then use Build Array and Byte Array To String to get your normal ASCII string.
GCentral
Message 11 of 14
(1,109 Views)
Okay found my problem. I didn't put flat sequence yesterday that's why have bug. All done after i put flat sequence in it.
Message 12 of 14
(1,100 Views)
You still do not understand Data flow! You can remove that flat sequence, it is redundant here. Just create a wire branch on the wire, after the While loop before the Array indicator, and connect conversion function to it before the string indicator. It is also just silly to use a local variable here.
If you are new to LabVIEW, there are lots of online training options, you can find here in a list, under section "Looking For Free Training": https://forums.ni.com/t5/Community-Documents/Unofficial-Forum-Rules-and-Guidelines/ta-p/3536495
And some reading about local variables, flat sequence structures, and more:
http://www.ni.com/newsletter/51735/en/
Message 13 of 14
(1,099 Views)
Yeah, avoid those Local Variables as much as possible.  Use wires.
Anyways, here is what I would do.  I used a FOR loop to make it a little easier on the compiler when creating the output array.  At these low sizes, it probably does not matter.  It would matter if we got into larger strings.
GCentral
Message 14 of 14
(1,090 Views)
