Array manipulations
I am working on acquiring data into arrays.
1. How do I fill arrays coulmnwise. From what I observe, it is filled row-wise all the time. I want the filling to happen columnwise.
2.  In row-wise filling of the array, how do I add up all the elements of a particular column?
Thanks.
Dheeraj Bharadwaj
IIT-Madras
Message 1 of 13
(3,131 Views)
Could you please explain what your application is?
Prashant
Message 2 of 13
(3,126 Views)
Hi Dheeraj,
Check this example.
Nitzz
(Give kudos to good Answers, Mark it as a Solution if your problem is Solved:smileywink:)
Message 3 of 13
(3,124 Views)
Are you working with 1D or 2D arrays?
If you are working on 1D arrays then you just need to exapnd the array down instead of sideways.
If you are working with a 2D array then you can simply add a transpose array function to get it to display in columns instead of rows. See below
Tim
GHSP
Message 4 of 13
(3,110 Views)
Hi Dheeraj,
If your array is 2 D array you can use transpose array function for changing rows to colums.
After transposing that you can use index array function.
The output of the index array function should be given to a sigma block found in Mathematics.
This will give you the sum of the elements of the column you are looking for.
Does this help??
"Winning isn't everything, Its the only thing"
Message 5 of 13
(3,105 Views)
@tigs
Please tell me where this sigma block exists. I am unable to locate it. I use LabVIEW 8.5
@nitzz
I'm sorry again, but the file you attached doesn't open because I use version 8.5
Thanks for your replies everyone, they really helped.
Dheeraj Bharadwaj
IIT-Madras
Message 6 of 13
(3,072 Views)
Accepted by dheeraj2102
Hi Dheeraj,
Sorry for that. I forgot about your LV version. This one is in 8.5. You can have a look. Everything that you need is explained on the block diagram.
Nitzz
Message 7 of 13
(3,054 Views)
The sigma block (Add array element block) is located at :---
Right click---> Numeric---> Add array element.
Does this solve ur problem
Message 8 of 13
(3,044 Views)
Just click on Accept as solution when your problem is solved.
Message 9 of 13
(3,041 Views)
Check this:
Sigma block(Add array element)
Message 10 of 13
(3,034 Views)
