Assigning string values to each numerical value of an array
I'm working on a project to create an "opening hand simulator" for a Magic: the Gathering deck. In my head, the idea is that I create a VI to shuffle a 60-card deck and display the top seven cards.
Well, I have the first part working fine - I have a VI that creates an array with values from 0 to 59, randomizes it, and then displays the first 7 values of the array. In other words, I hit Run and it spits out seven random numbers from 0-59 with no duplicates, just like if you shuffle a 60-card deck and draw seven cards.
But I want to go a step further and assign a string value (the name of a Magic card) to each numerical value in the array - so, 0 = "Island", 1 = "Lightning Bolt", and so on. That way when I hit Run, I will get a display of seven card names instead of seven numbers.
So, how would I go about 1) assigning a string value of my choice to each of the 60 numerical values in this array, and 2) display the values of this randomized array as the aforementioned string values?
Message 1 of 11
(6,205 Views)
Accepted by jrkh8er20
Several options here, but the easiest i see is to use the numerical values to localize an array of strings. So have a separate array of strings, and use the numerical values to index the array and pull the string at that index value.
[edit] Example:Card Shuffle.png
-Matt
Message 2 of 11
(6,198 Views)
That worked perfectly, thanks!
Message 3 of 11
(6,177 Views)
hi, taking advantage of your suggestion... what if i have an array of a hundred strings but in my front painel i just want to display 4 strings that will be selected automatically. in my cases the strings in my front painel will be alarms, so i have a hundred possible alarm messages that shall be displayed when the corresponding boolean is set true.
thank you.
Message 4 of 11
(6,106 Views)
Can you pose a snippet of your most recent code? Add some comments to Portray what you're trying to accomplish. I'm just a little confused what you're trying to do.
-Matt
Message 5 of 11
(6,099 Views)
Hi, i am sending an example describing what i want to do. And rembering that i don't know if my approach is the best one, so if you have a solution using other elements it will be welcome.
thank you in advance.
Message 6 of 11
(6,088 Views)
I would try something like this. You had several alarm elements, i just put those into an array, arrays are generally much easier to work with than several of the same type elements.
-Matt
Message 7 of 11
(6,066 Views)
Thank you very much. It worked perfectly.
Message 8 of 11
(6,056 Views)
Use an enum type def and those strings can travel places without having to update the string array constants in several places each time you add a new alarm
(Look ma no case struscture to hide code in)
"Should be" isn't "Is" -Jay
Message 9 of 11
(6,051 Views)
Thank you too, i'll try. I never saw this conditional tunel, looks interesting.
Message 10 of 11
(6,039 Views)
