Assignment help - new
Please help, i need help with the following assignment, I am new to this and so I am pretty stuck:
This assignment is designed to work on a sampled TTL square wave of up to 100 samples stored in an appropriate array. The two logic states are represented by the following values:
          A logic 1 (High) by a value of 5 + 0.5 (V).
          A logic 0 (low) by a value of 0 + 0.5 (V).
Specification 1 (65%)
To design a VI that will identify every transition between either of the two states and calculate the number of Logic 1s as a percentage of the total number of samples.
The front panel will consist of the following:
          An array of controls holding the sampled values.
          An array of indicators holding the index values of where each transitions occurred.
          An indicator holding the percentage of high values.
Hint: Research Build array and Initialise array functions.
Specification 2 (75%)
To design a VI that will meet specification 1 and can also be used as a sub VI in another VI. The sub VI should be fully documented, have its own icon and connector pane.
Specification 3 (100%)
To design a VI that will meet Specification 2 and will also be capable of detecting any errors that occur: i.e. samples that fall outside the permitted ranges. If errors are detected analysis should be aborted and the samples in error identified in an appropriate manner.
Message 1 of 11
(5,416 Views)
Start here.  It'll get you very far.
Jim
Message 2 of 11
(5,400 Views)
Thanks for that...
But I am asking for help, not a solution! I am pretty stumped.
Message 3 of 11
(5,394 Views)
And what help are you asking for?
What have you done so far?
What hardware do you have?
What LabVIEW version do you have?
Message 4 of 11
(5,380 Views)
A point in the right direction, a starting point.
I was trying to do a paper trace but keep hitting a wall. I made an array but was unsure about which values should go into it. I was trying to find a way to identify the transitions but really am not sure how to do it. And then calculating the number of logic ones as a percentage of the total number of samples is a whole other story...
I am using a PC
Versio 8.6 of labVIEW
Message 5 of 11
(5,373 Views)
Shift Registers are your friend here.  Use a shift register to keep track of your transition locations, another one for the number of 1s, and a third for keeping the previous state.  By keeping the previous state, you can check to see if the previous state and the new state are different (a transition occurred).
GCentral
Message 6 of 11
(5,359 Views)
Ok thanks, hopefully a start in the right direction 🙂
Message 7 of 11
(5,356 Views)
Here's a quick-and-dirty sample data generator.  It's something to get you started looking for the transitions.
Jim
Message 8 of 11
(5,349 Views)
Thanks Jim, much appreciated.
Message 9 of 11
(5,345 Views)
thank you jim
Message 10 of 11
(4,472 Views)
