Average Value Scope
Doing something manually has absolutely nothing to do with code or for loops or timeouts. I don't see why you don't understand what you've been told to do. Just walk away from your computer.
Message 21 of 46
(4,304 Views)
Yes ı made it sir .
Message 22 of 46
(4,300 Views)
What time base (seconds/division) are you using?
GCentral
Message 23 of 46
(4,293 Views)
What is time base sir . Can ı understand in attachment ?
Message 24 of 46
(4,284 Views)
In all seriousness, if you do not understand what I mean by time base, you need to go find a professor and have them teach you how to use an oscilloscope.
Time base is the number of seconds per division in the horizontal axis.  It looks like you are using 500ms/division.  Since there are 10 divisions on the screen, you are capturing 5 seconds worth of data per trigger.  So in order to capture 512 waveforms to average, you will be waiting at least 42 minutes.  Since it looks like the interesting part of your waveform is 4 divisions (2 seconds), you could decrease your time base to 200ms.
Since you are also going for an average waveform, you should not use an auto trigger.  A trigger level of 0.5V on a rising edge should work well for you.
GCentral
Message 25 of 46
(4,269 Views)
Thank you so much sir.
Message 26 of 46
(4,258 Views)
Hello sir ,
I made exactly what you say. I configure  #Average 512  in my scope and ı see the signal in my scope .  But when ı  run same vi, again vi is not working and says "VISA:  (Hex 0xBFFF0015) Timeout expired before operation completed."
AND eror :
What should ı do ?
Message 27 of 46
(4,170 Views)
2ms/div*10div = 20ms of data per cycle.  Multiply that by 512 cycles needed for the average and we get ~10.25 seconds.  I'm willing to bet that your VISA timeout is set to 10 seconds.  So of course you are going to get a timeout.  And that is not counting the time between the signal pulses.  How often are those singnals sent?
In short, you need to add delays to your code in order to allow for the signals to be fully captured before you can get them.
GCentral
Message 28 of 46
(4,154 Views)
When ı looked the quick drop. I didn't find delay. What should ı  do sir ?
Message 29 of 46
(4,148 Views)
Take some tutorials.  The Wait (ms) is one of the most important functions when dealing with instruments.
3 Hour Introduction
6 Hour Introduction
LabVEW Basics
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
Learning NI
Getting Started with NI Products
GCentral
Message 30 of 46
(4,143 Views)
