BER
i am trying to reduce my ber with the help of attatched vi. i am transmitting my modulated waveform from one vi to second vi for getting my original sent bits after demodulating it. if i connect the modulating and demodulating part without datx vi's( these vi belongs to daq card(kusb-3116)) which i am using for analog output and analog input channels, i am getting ber=0 but when i put my daq card inbetween them(modulating and demodulating) part. i get ber=1 . kindly help me with its synchronization etc. i am totally new in labview. i tried to read detailed help of  MT Generate sync parameters, but couldn't get that what is meant by sync bit, sync seq and sync found index etc.
nauman
(3,066 Views)
I don't know if this helps or not, but have you seen this post
http://208.74.204.114/t5/LabVIEW/How-to-use-Generate-Synchronization-Parameters-for-PSK/m-p/1767494
Nathan S.
Applications Engineer
(3,020 Views)
