12-05-2016 09:43 AM
Hello Guys,
I am trying to connect my gigaE camera from Baumer with cRIO 9022 via ethernet port but I can not discover the camera in MAX. I also tried to connect the camera directly to PC and it works fine. I checked for the IMAQdx drivers on my cRIO and they are properly installed.
Secondly, I also tried to connect to the USB port of cRIO (with ethernet to USB 3 converter) but still I can not see the camera in my MAX device list.
Please suggest some possible solution.
12-06-2016 07:18 AM
have you checked if the camera and cRIOs second ethernet port have propper IP settings e.g. are in the same subnet?
Kind regards
Heinz
12-06-2016 07:26 AM
Hello ,
Yes, I checked this as well. but cRIO and Camera are in same subnet.
Himanshu Sharma
12-06-2016
07:50 AM
- last edited on
01-06-2025
10:31 AM
by
Content Cleaner
are you sure your setup should work since the controller is rather old?
This KB states:
"GigE Vision
Cameras following the GigE Vision standard are supported by high-performance, multi-core cRIO devices, such as the cRIO-908x and cRIO-903x series. There are currently no sbRIO targets that support GigE Vision cameras."
If it is an IP camera then try this link:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x4IqCAI&l=en-US
But it seems there are only Basler and AXis cameras supported...
12-06-2016 07:59 AM
Yes, I consider this as a compatibilty issue between camera and cRIO type.
Thank you
Himanshu
