Benchmarking PXIe based Data Acquisition
HI,
pls find the VI snippet of the code for RT acquisition with logging. I found no difference if I disabled the graphs in the code. the cores are almost running at 98-99% load for the code.
Pls let me know if this can be further optimized
Message 11 of 26
(949 Views)
You're kidding me, a 14 MB picture?  It's either HUGE or impossibly tiny.
Not very helpful.
Message 12 of 26
(937 Views)
I thought the snippet would be helpful...pls find the vi attached ..
regards
Message 13 of 26
(919 Views)
Combine all of those DAQmx tasks into a single task with all of the channels.
Consider using TDMS streaming to file.
Do you really use a queue size of "1"?
Ben
Message 14 of 26
(904 Views)
You definitely do not want a queue size of only 1.   Your queues would all be full immediately.  This might explain why your CPU is jumping to 100% immediately.
Try a value of -1 while keeping an eye on your queue sizes.
Patrick Allen: FunctionalityUnlimited.ca
Message 15 of 26
(897 Views)
more thoughts...
If that code is what you are actually trying to use then the math works out to "3600000" or about 3.6 MS/s. That was possible on old Pentiums.
About 2 years ago I was pulling in 400MS/s continuously using a PXIe chassis.
Go with TDMS streaming and only use the queue to share data with a graph AFTER you get the acquisition running right.
Ben
Message 16 of 26
(888 Views)
When I tried combining multiple tasks I was getting the error. In earlier posts I concluded that this might not be possible in RT systems.
Queue size of 1 was kept since I believed that larger sizes will lead to memory issues. Keeping -1 is doing dynamic allocation which is generally in efficient.
Correct me if my understanding is wrong. I will run the code and post the results again here with -1 queue size.
Message 17 of 26
(887 Views)
Since you have identical boards, combine all the channels from each board into 1 task.
Start from the beginning.
  1. Go to the Help - Find Examples
  2. Choose Voltage - Continuous Input
  3. In the channel settings part of the example, choose channels from separate boards. (See below)
  4. Look how the TDMS logging is done in the example, NO producer-consumer.
mcduff
Message 18 of 26
(877 Views)
The key concept here is that you're using the queue (memory) as a temporary buffer for your data.
If you're collecting data points faster than you are processing them, then your queue will grow in size.  This isn't necessarily a "bad thing".   It can be pretty typical for short duration, acquire-analyze-display DAQ applications.
Where you could run into problems might be a continuous DAQ application where your queue grows until your target runs out of available memory and then throws an error.
Message 19 of 26
(874 Views)
I've been away from RT a while, but I expect the more memory-safe limited-size RTFIFO might be a viable alternative to a standard queue?
I seem to recall Ben posting about filling (and then emptying) the RTFIFO one time during initialization.  Thereafter, you can be assured that no new memory allocations will need to happen.  (Or maybe he did this with regular queues, and the same assurance is inherently built into RTFIFOs when you create one?).
Offering some breadcrumbs, others with recent RT experience can hopefully expand or correct as needed.
-Kevin P
Message 20 of 26
(862 Views)
