Blackfin Multi-Threaded Applications with Events
Hi JoeC,
Going back to your first post, you said when you added the second loop this continuous running of the top loop started. However if you run just the top loop of the code, it still have this problem: 1 loop.png
What are you trying to acheive? R&D is trying to gain more understanding on your application.
Claire
Claire Reid
Message 11 of 15
(923 Views)
Right now my application has a couple of loops running in the background doing RS-232 communication and collection of SPI port data that interfaces an AD7476A.  There are 3 other loops displaying data on the front panel.
I am then using the event structure to monitor for touch panel interaction.  It would be extremely beneficial to have this process sleep instead of continuously polling to see if something changed on the front panel.  This would save CPU cycles monitoring if something on the front panel has changed.
Message 12 of 15
(921 Views)
Hi JoeC,
Thanks for this information. Let me put together some more examples to demonstrate the problem to R&D.
Claire
Claire Reid
Message 13 of 15
(903 Views)
Hi-
I am filing a Corrective Action Request to R&D about this issue. I will post the number for the CAR once I file it.
Claire Reid
Message 14 of 15
(891 Views)
Hey JoeC,
The correction action report number is 190016 (if this issue is fixed in future releases, the fix will be linked with this number). I will let you know if I hear of any progress on this issue.
Claire
Claire Reid
Message 15 of 15
(880 Views)
