Blinking LED without property node
Hey!
I am familiar with property node blinking but I want to make a LED blink because of a timer interfering with a FOR cycle. I have almost made a VI that compares timer value to y value. When timer value is larger than y, then my LED should shine. When timer value is smaller than y then it should turn off. Something is wrong, maybe someone could help me.
Message 1 of 17
(14,711 Views)
What exactly are you trying to do over here?
- You have enabled indexing on the output index of the for loop; which means that you are comparing the timer value with an array of 50 elements. The output of the greater than function is an array of 50 booleans. You will not be able to wire that to an indicator.
- What is the 'i' variable in your formula node? You haven't defined that as an input.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 2 of 17
(14,701 Views)
1) My idea is that every 500 miliseconds timer value is compared to some y value. I think it should work if timer everytime starts from value "0".
2) Yes, I meant this i from FOR cycle. I guess I haven't connected it anywhere.
Adnan, maybe you have other ideas, how to create blinking?
Message 3 of 17
(14,692 Views)
We could help you but you need to help us understand what exactly you are trying to achieve. From what I understand, you just want to turn the boolean indicator on and off to simulate blinking. But, can you explain the idea of when to turn the indicator on and off?
Adnan Zafar
Message 4 of 17
(14,678 Views)
0 miliseconds: on
500 miliseconds: off
1000 miliseconds: on
1500 miliseconds: off
2000 miliseconds: on
2500 miliseconds: off
Message 5 of 17
(14,671 Views)
Well Smiley Indifferent if it's based on nothing, then put the Express VI "Elapsed Time" wired to 0.5 seconds and a LED on the output "Time has Elapsed" in a while loop and away it goes.
Richard
Message 6 of 17
(14,665 Views)
Accepted by kukonens
I came up with this real quick. I am sure there are much elegant ways to do this.
Adnan Zafar
Message 7 of 17
(14,662 Views)
If the OP's loop if 500mS, which, after looking at the code, I think maybe it will be once it is fixed, then this is all we need... (also note that he wants to start High)
Richard
Message 8 of 17
(14,659 Views)
thank you guys! you're the best 🙂
Message 9 of 17
(14,644 Views)
Here are two simpler versions that don't involve any "math" and operate "in place". Pick one! 😄
Message 10 of 17
(14,628 Views)
