Block diagram style is not the style I set for the front panel, LabVIEW 2022 Q3.
I set my default style to be 'NXG', however when I create a control or indicator in the block diagram, on a DAQmx terminal, the corresponding item on the front panel is in the 'modern' style instead of 'NXG'. I have to manually replace it with a NXG style control or indicator in the front panel. Is there a setting to fix this?
I've attached a screenshot.
Message 1 of 13
(380 Views)
When you create these new controls, are you selecting them from the Modern palette?  The default setting for control style only affects the controls that are created by right clicking a subVI input and creating a control/indicator from there.
aputman
Heads up! NI has moved LabVIEW to a mandatory SaaS subscription policy, along with a big price increase. Make your voice heard.
Message 2 of 13
(366 Views)
There is also this note from the help file.
aputman
Message 3 of 13
(363 Views)
Some subVIs uses Strick Type Def. , especially drivers like DAQmx.
So LabVIEW has to use the style of the subVI when you create from diagram.
No, you can't fix this by yourself.  Make a suggestion in the idea exchange forum.  Wait NI fixing it for you.
George Zou
Message 4 of 13
(362 Views)
I'm really new to LabVIEW so I'm not sure. I right click on the data part of the DAQmx item, then click create control or create indicator, as shown in my diagrams:
It is modern in the front diagram. If I want to change it I then have to click replace and replace it with the NXG version.
I also checked the way you showed in your picture, and when I click create control it uses the modern version not NXG.
Message 5 of 13
(356 Views)
When creating a new control/indicator from a subVI call, the new control/indicator will be a copy of what is in the subVI.
GCentral
Message 6 of 13
(321 Views)
LabVIEW uses the VI property "Editor Options" > "Control Style for Create Control/Indicator" in the following situations:
 - when you right-click a constant and choose "Change to Control" or "Change to Indicator" ;
 - when you right-click a terminal that does not belong to a SubVI (e.g. yellow functions, property nodes, method nodes, conditional terminals, iteration terminals...) and choose "Create Control" or "Create Indicator" ;
 - when you right-click a wire whose source is not a SubVI terminal and choose "Create Control" or "Create Indicator".
However when you right-click the terminal of a SubVI ( = node that calls another VI) or a wire whose source is a SubVI terminal, such as the DAQmx subVIs, LabVIEW will always use the style of the object from the SubVI's front panel.
This is a bit silly but the workaround could be:
 - create your control/indicator from your SubVI terminal or wire ;
 - change it into a constant
 - change it back into a control or indicator
Raphaël.
Message 7 of 13
(312 Views)
You can create the constant from the terminal directly, combining #1 and #2
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 13
(263 Views)
Thanks all for the suggestions. I think I'll use the one where I create a constant first and then change it to control / indicator. I realise now that the front panel of the DAQmx module is in the 'modern' style which is why it is being made into 'modern' when I create the control / indicator - possibly something NI could work into a new version to change the DAQmx front panel items to whatever you choose as your default style across the board.
Many thanks for all the help!
Message 9 of 13
(259 Views)
If you go to the options for LabVIEW you can set the default to what ever you want:
Tim
GHSP
Message 10 of 13
(229 Views)
