Bluetooth connection in CompactRIO
Can I make a CompactRIO communicate with a Bluetooth device?
I have a pressure gauge from Wika (https://www.wika.com/en-en/cpg1500.WIKA) that communicates via BT. Can I somehow connect a CompactRIO using an USB Bluetooth dongle with this device?
Tamas
(976 Views)
Accepted by topic author tcsabina
Someone has tested with Cirago Bluetooth 4.0 previously. However, there are no supported Bluetooth palettes in LabVIEW. You need to use the bluetooth libraries provided by third party and call it using CLFN.
USB Devices tested on NI Linux RT (myRIO/cRIO-9068)
Control Lead | Intelline Inc
(947 Views)
Thanks.
In the meanwhile I got a response from my NI representative, stating that although it should work, it is not officially supported. So use it at your own risk.
(943 Views)
