Bluetooth low energy
Hi
Does any one have a Example VI for discover a Bluetooth low energy device? I am using labview 12 and windows 7/8.1.
Darren
(3,451 Views)
anymore hardware details?? what type of bluetooth (Version)? Short/long Distance? Isolation? for RX or TX or both? info like that would be useful
___________________________________________________________________
"I have not failed. I've just found 10000 ways that won't work." - Thomas A. Edison
(3,281 Views)
I am not the original poster, however I need the same thing. I am using the cc2540 dongle as a detector and the "bluestart.vi" is complainging with error 59 which apparently means it is refusing to communicate with the drivers i have used since they are TI drivers and not microsoft. so I wanted to see an example of someone who was able to cirumvent this issue one way or another, even if this meant using a different kind of dongle. I just need a device that are capable of seeing and communicating with BLE devices (mine is BLE112)
i think some said they were able to do so through the VISA interface. i would love to see an example of that or anything that would work with BLEs. I am updating an old labview program that used bluetooth so it will be able to use BLE so I can't start from scract completely and would love if i am able to just subtitute the VI with a different VI that works
(3,212 Views)
I would like to know if anyone acomplished this.  I'm trying to connect to a BLE device.  It shows up in the Windows Bluetooth explorer (using a 3rd party Bluetooth 4.0 dongle), but I can't seem to find it when I try to discover it in Labview
(2,977 Views)
Did you make it work?
I have a BLE112 USB Dongle and would like to use it in my application.
Can you share your results please? may be the VIs?
Thank you
(2,803 Views)
