06-28-2013 01:29 PM
Okay, attached my VI and the .NET dll.
This VI I want to use for discovering all bluetooth devices and selecting the one with which the pairing should be done.
Anybody suggestions how to solve it in a way that the bluetooth devices connects (and stays connected) and opens a virtual serial port?
07-01-2013 08:22 AM - edited 07-01-2013 08:23 AM
Hello thls.
Thanks for the code.
Based on the previous posts it seems like the main issue is the detection of the gsm.
I did some tests at my side with my cell phone and just made some relatively simple code that just slowly increases the detection time until you detect the cell phone.
I also saw that 4 to 5 seconds detection time always seems to be enough.
This is comparable to the amount of time Windows would take the first time it would try to detect your phone.
Can you try this and let me know if it resolves your Bluetooth detection issues?
The attached Code is provided As Is. It has not been tested or validated as a product, for use in a deployed application or system, or for use in hazardous environments. You assume all risks for use of the Code and use of the Code is subject to the Sample Code License Terms which can be found at: http://ni.com/samplecodelicense.
07-01-2013 10:30 AM
Thanks for the quick response.......and hopefully the sollution, how ease can it be?
But can add the VI saved in Labview 2011?
I can't open it.
07-01-2013 11:50 AM
Here's the 2011 version.
Please let me know if something is unclear.
07-01-2013 12:59 PM
So far, so good!
That's clear, but what about the rest of the proces?
When the discovering is done, I have to pair and init the serialport "service"
Do I have to put that part at the point which I marked in the attachement?
Because when I enter the BT Close reference I have to start over again.
Thanks!
Keep you updated!
07-02-2013 06:37 AM
Hello thls,
You should indeed put this before the closing of your references.
I adapted the example and added documentation with the reasons also.
Basically what you should use as reference material are these pages and the linked pages from over there:
http://32feet.codeplex.com/documentation?referringTitle=Home
http://32feet.codeplex.com/wikipage?title=Bluetooth%20Serial%20Ports&referringTitle=Documentation
http://inthehand.com/library/32feet/
PS: It is totally not yet perfect code (probably also some Rube Goldbergs in there), but I just wanted to explain the concept a bit.
07-02-2013 06:38 AM
And here the 2011 code.
08-20-2013 03:58 PM - edited 08-20-2013 03:58 PM
For anyone interested in this example.
Please also take a look at the following simple class API example/"starting point":
https://decibel.ni.com/content/docs/DOC-31353
11-06-2015 02:25 AM
when pairing,windows 7 will appear below windows,is there any way to disable this,or progammaticly click next button?tks
11-10-2015 12:21 AM
Can someone can tell me some info about the pairing?
evenif i set pin 0000,however device and PC still will popup dialog with random number as above pic?
any ideas is appreciated.
