Boolean Switch Auto On/ Off with respect to a case structure
Hi all,
 I have attached My VI. The  Boolean switch has enter into   True and  false  case structure automatically. How can I connect the Boolean switch to make it happen please.
(936 Views)
@RRBB wrote:
Hi all,
Not able able to open the attached VI ( Not all Forum users will be using the latest versions its better to share the lower version)
Based on your statement, I guess using shift register will solve your problem.
(872 Views)
Not sure what you are trying to implement here.
Note that the Boolean control is only read once since it is placed before the loops.
https://tmesystems.net/
(856 Views)
yes that's right. when I  don't click the boolean button the false statement runs. when I click on Boolean button true statement runs. THis functions happens only manually. I want to make it auto.
(819 Views)
Accepted by topic author RRBB
used a FOR loop for boolean button with not logic. solved. Thanks
(806 Views)
