Build Error LV 2011 (32-bit installed on 64-bit Windows 7)
While building an exe file, got this error:
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 1 occurred at Invoke Node in AB_Build.lvclass:Copy_Files.vi->AB_Application.lvclass:Copy_Files.vi->AB_EXE.lvclass:Copy_Files.vi->AB_Build.lvclass:Build.vi->AB_Application.lvclass:Build.vi->AB_EXE.lvclass:Build.vi->AB_Build.lvclass:Build_from_Wizard.vi->AB_UI_Frmwk_Build.lvclass:Build.vi->AB_UI_FRAMEWORK.vi->AB_Item_OnDoProperties.vi->AB_Item_OnDoProperties.vi.ProxyCaller
Possible reason(s):
LabVIEW: An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @.
Method Name: Linker:Write Info To File
The file output is set to local C:\build\App\ folder; however the source files are localed on a shared drive. What could be the problem? I do not see any output files in the specified folder on C drive.
(2,503 Views)
Also tried to build the exe file (same project) on 32-bit Windows 7, 32-bit LV 2011. Got this error:
Error 6 occurred at Delete in AB_Engine_Delete_Internal_Files.vi->AB_EXE.lvclass:Build.vi->AB_Build.lvclass:Build_from_Wizard.vi->AB_UI_Frmwk_Build.lvclass:Build.vi->AB_UI_FRAMEWORK.vi->AB_Item_OnDoProperties.vi->AB_Item_OnDoProperties.vi.ProxyCaller
Possible reason(s):
LabVIEW: Generic file I/O error.
Any ideas?
(2,499 Views)
Accepted by topic author Vladiator
Found a solution. Had to copy all files on a local drive, and then re-create the lvproj project structure. Only then I was able to build an exe without errors.
(2,477 Views)
