12-19-2024 10:23 AM
É que os tudo que é referente ao mesmo item deve estar dentro do mesmo objeto daquele equipamento, assim que funciona a uma estrutura json
12-19-2024 10:35 AM
Translated with deepl:
It's just that everything that refers to the same item must be inside the same object of that equipment, that's how a json structure works.
You wrote about 'how remove the duplicates of my JSON'. But I don't see any duplicates.
What is your expected JSON structure?
Do you want something like: EQ1 { TCP { 1{}, 2{}, 3{} } }, EQ2 { TCP { 1{}, 2{}, 3{} } } ?
12-19-2024 11:01 AM
I'm sorry for my bad English, but that's exactly what I need
12-19-2024 12:53 PM
Could you help me with this?
12-19-2024 03:08 PM
I do not use JSONText in this way usually, but this would get you there without having to define the cluster.
Defining the cluster seems comparatively easier, if it is fixed.
12-19-2024 03:59 PM
12-20-2024 04:41 AM
Thank you so much, work's perfectly
