Build a string with mixture of Text, number, space and enter
Hi all,
I am trying to build a string with mixture of Text, number, space and enter. The content and format of the string should be 'UOL0001 1 2 3' followd by an enter.
Please find it in the attachment, what I am trying to input is ' UOL0001\s1\s2\s3\n'. But it came out wrong. Any idea how to do it? Many thanks.
Sam
Message 1 of 9
(3,757 Views)
Accepted by SamGao
Hi SamGao,
Check the following example. Even I don't know what is going wrong with the VI which you made. But to avoid that error, if you want to add a space (\s) or enter(\n) instead of typing it as such, after clicking inside the control just press space bar or enter key once. Then rightclick inside the control and select '\' codes display. Then you will see the \s and \n appearing in the indicator and the code will work fine.
Nitzz
(Give Kudos to good Answers and Mark it as a Solution if your problem is Solved;))
Message 2 of 9
(3,753 Views)
You're using "Normal display" on your strings, thus "\s" isn't interpreted but written as "\s". R-click the controls and change to "\\ Codes display"
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 9
(3,741 Views)
One curiosity is that you are using array to spreadsheet string?  Why are you doing this?  Why not simply use number to decimal string, for your decimal, and for your enter you can use the carriage return constant.  (these are on the strings menu).
-Regards
eximo
_______________________________________________
UofL Bioengineering M.S.
Neuronetrix
"I had rather be right than be president" -Henry Clay
Message 4 of 9
(3,727 Views)
Here I rewrote the code
-Regards
eximo
Neuronetrix
Message 5 of 9
(3,726 Views)
don't forget to dole out some kudos to these guys, and mark this as a solution if it helps, if it doesn't, then try elaborating, we are here to help
-Regards
eximo
Neuronetrix
Message 6 of 9
(3,723 Views)
You might also consider Format Into String.  It's cleaner on the block diagram and easier to modify if you come back later.  The format string controls the output.  %s indicates a string, %d is a decimal number, %f is a floating point number and the .3 in front indicates I want a precision of 3 digits. \n prints a newline and the spaces between the %<> are printed as is.  There are many other options to the format string.
--Using LV8.2, 8.6, 2009, 2012--
Message 7 of 9
(3,709 Views)
Or, you could just do this:
EDIT: I see that taper provided the alternative prior to me being able to finish my post - my post was stuck due to NI server problems.
Message 8 of 9
(3,703 Views)
Many thanks, guys. The problem solved!
Sam
Message 9 of 9
(3,662 Views)
