06-06-2014 08:06 AM
I've a big application and now i want to build it, when i have all the settings filled in, i push build, in the taskmanager i see the memory labview is using rise to 1,6 Gb then boom, the build status says it's done but when i push "explore" i'm directed to an emty folder and when i click "done" my project hangs...?
what is wrong? i include an ini file, but that wouldn't cause this?
Thijs
06-06-2014 08:17 AM
Impossible to say without seeing at least a bit of your code -- or failing that, how about some information like what version of LV? What OS? What drivers are you using? Have you been able to build other applications? Have you been able to ever build this application?
Mike...
06-06-2014 08:33 AM
06-06-2014 08:49 AM
So the only external drivers of any sort is DAQmx?
Do you still have an archive of the project before the changes that you can try building?
If you build a small application that just does something simple like return a random number, does that work?
Have you added or changed anything on the computer in the last two weeks?
Mike...
06-06-2014 09:11 AM
06-06-2014 09:15 AM
If something went wrong during the install, you bet your life it could cause this!
Mike...
06-10-2014 02:29 AM
I tried it on another PC with another install of Labview, same problem... I also tried to make a small program where a for loop fills an array. Then when i make an executable out of it it works great.
I really don't have clue? Is there a sub VI limit? I use around 130 sub VI's in my application and when it loads the first time the number of vi's loaded are around 500...
Thijs
06-10-2014 10:06 AM
No, there is no VI limit.
MIke...
06-11-2014 06:00 AM
After several updates for windows 7 it just works?? I realy don't understand...
Thijs
06-11-2014 08:54 AM
Again, if windows was badly out of date there could be a piece missing that the builder needed when creating larger applications. But hey, you can't argue with success.
Mike...
