Buttons won't work in event based state machine
Hi everyone,
I was following the instructions for state machine construction in a tutorial and the code doesn't seem to work. It looks like the buttons placed inside the event structure are not being executed like they were in the video. I am confused as to where I went wrong since everything I did looks the same as the tutorial. I have attached the code and the type def created.
Thanks in advance!
Tutorial link: https://www.youtube.com/watch?v=RuIN31rSO2k&ab_channel=NationalInstrumentsEasternEurope
(557 Views)
Hi ruth,
For me the VI works as expected (from code review) - but I didn't watch the video…
What is your expectation and where does the VI don't follow your expectation?
(517 Views)
Accepted by topic author mako_ruth
Hi GerdW,
Turns out the embedded UI needs to be enabled on my CRIO 9038 before using the event structures! Did not know that beforehand so I was quite confused and thanks for the code review.
https://www.ni.com/docs/en-US/bundle/labview-real-time-module/page/lvrthowto/deskenv_enable.html
Cheers,
Ruth
(481 Views)
Hi Ruth,
I was quite confused …
Yes, you even forgot to mention any cRIO in your first message…
(469 Views)
