CANopen Fetch from Data
I have dragged this subvi Fetch from Data  of CANopen.
But i got the problem with "One or more polymorphic instances have a connector pane that is incompatible with the connector panes of other instances."
How can i solve it?
(2,268 Views)
Hi Zhangfy,
then you have accidently changed one instance of that polymorphic VI even though you should NOT CHANGE VIs from (NI-supplied) libraries…
@Zhangfy wrote:
How can i solve it?
  1. Use your SCC system to revert back to a working version of this VI. When you don't use any SCC system: start using one!
  2. Pick a backup with a working/unchanged version of this VI. When you don't use backups: start using them!
  3. Reinstall the CANopen driver with all VIs…
(2,252 Views)
May i copy the CANopen vi.lib from another computer?
(2,246 Views)
Accepted by Zhangfy
Yes.
(2,233 Views)
