CPU Usage
Hi guys!
I would like to know if its possible get CPU usage from a VI while running(exe in a future)
Thanks.
(888 Views)
Hi Ivan,
Do you want the CPU load of a single VI or the whole program?
Getting the CPU load of the whole program is possible using Windows function calls…
(885 Views)
Hi Gerd,
@GerdW  ha escrito:
Hi Ivan,
Whole program. I tried with function calls but i haven't found out. If you can help me i appreciate so much.
(860 Views)
Hi Ivan,
when using my favorite search engine for "labview cpu usage" I find a lot of websites discussing your problem, like this or that one…
(833 Views)
If you want to be system independent (.Net only works on Windows) you can use the NI System Control API. An example showing how this works would be at <LabVIEW>\examples\nisyscfg\Resource Monitor.vi
Rolf Kalbermatter
My Blog
(819 Views)
@GerdW  ha escrito:
Hi Ivan,
Thank you Gerd, I'm gonna check!
(719 Views)
@rolfk  ha escrito:
thank you mate!
(718 Views)
