Call and open an external excel file with system exec vi
Hello!
I would like to know how I could call and open an external excel file with the system exec vi. I am able to call a txt file, however i cannot do it with an excel file...
Thanks a lot in advance.
(5,090 Views)
Hi jess,
when Excel is the default program associated with Excel files it should open automatically when you try to "start" an Excel file via SystemExec!
What have you tried so far?
(5,086 Views)
Why would you want to do that?  What version of LabVIEW are you running?  What are you trying to do?
(5,066 Views)
Accepted by jess1006
It should work just like any other file, it opens it in the default program for that file extension as if you double clicked it.  Here is an example if code I use.
(5,060 Views)
Thank you!
What function are you using just before the system exec vi?
I can´t find it..
So far i have tried writing in the command line the complete path including the name of the excel file
(5,047 Views)
That image is a snippet, it is executable code, no need to recreate it.
http://www.ni.com/tutorial/9330/en/
(5,040 Views)
Thank you so much for your help Hooovahh
(5,036 Views)
