Hey All,
I've developed a custom serial interface on a PXI7831R. Intermittently a call to the FPGA vi causes the computer to reboot. One instance of when this occurred recently. The FPGA vi is used to stimulate a product that is undergoing Environmental Stress Screening or ESS. Placed in an 'oven' that is controlled via GPIB, the product is powered on and tested 3 times at the end of a hot soak and again at the cold soak. Each hot and cold soak is called a cycle. The LabVIEW software ran for 4 cycles or 24 calls to the FPGA vi with out any problems. Then, on the 5th cycle, the software caused the PXI rack to reboot on the first test.
18 slot PXI Chassis
8187 PXI Controller, Windows 2000, LabVIEW 7.1, latest everything
2503 switch card
7831R FPGA card
There is a TTL level to 422 level voltage shifter chip from Maxim that uses 5 volts from the FPGA card. Testing shows that at most the chip draws 0.054 Amps, way below the supposed 1 Amp available (per the manual).
We do use interrupts and we tried the NiViPxiK.sys patch, but that caused a crash on every use, made things worse.
Any ideas?
-Andrew
