Calling stored procedures with parameters with the Database Connectivity Toolkit
I created a stored procedure on my machine just like yours using my own table.  Using the code below I got a value of 17 (verified in SSMS),  Did you modify the Create Parameterized Query VI as I originally stated in my first post?
 CREATE PROCEDURE getLastSequenceNumber
    -- Add the parameters for the stored procedure here
    @p1 nvarchar(10) = ''
AS
BEGIN
    -- SET NOCOUNT ON added to prevent extra result sets from
    -- interfering with SELECT statements.
    SET NOCOUNT ON;
    -- Insert statements for procedure here
    SELECT max(pk_tporlog) from tporlog where cuserid = @p1;
END
GO
aputman
Message 21 of 25
(2,060 Views)
I did not modify the Create Parameterized Query VI.  I just did and now it works!  Thanks so much for all the time and effort you put in to helping me, it is much appreciated and was a huge help.
Message 22 of 25
(2,049 Views)
Attached is a VI that will:
(a) Open a connection to MS SQL Server database,
(b) Run a parameter laden stored procedure by name,  and
(c) Return results table if any w/column names.
Other features are:
1. Return second table of results (2nd table of results)
2. Execute Stored Procedure is a Global VI that can be run from anywhere (e.g. subVIs) in the code
For the connection string you can also use the SQL Native Client connectivity string:
Driver={SQL Server Native Client 11.0};Server=myServerAddress;
Database
=myDataBase;Uid=myUsername;Pwd=myPassword;
Be sure that you have installed the MS SQL Server native client driver ver: 11.
This one uses ADO (legacy).
See attached VI library.
Anthony Lukindo
Mezintel Inc.
Message 23 of 25
(1,819 Views)
You can use this example which is tested.
Message 24 of 25
(1,483 Views)
