Can I generate a triangle, square and saw tooth wave from an array of points?
The non elegant code is because I am using labVIEW for the first time.
Is there a way by which I can specify the negative and the postive limits for the data points. Like in Example.vi with an amplitude of 1, the waveform starts at 0, goes to 1 -> -1 -> 0. Can i have a waveform that starts at -1 -> 1 -> -1
Message 11 of 16
(885 Views)
The non elegant code is beacuase I am using LabVIEW for the first time.
I understabd that the waveform starts at 0, goes to the max amplitude and then the min amplitude.
Can I have a waveform that starts at the min amplitude, goes to the max amplitude, and then returns to the min i.e. if amplitude is 1, the waveform goes form -1 -> 1 -> -1 ?
Message 12 of 16
(883 Views)
If you use the example that i gave you all you have to do is set the amplitude to the desired level.
Tim
GHSP
Message 13 of 16
(876 Views)
Adjusting the amplitude works fine in cases when the magnitude  of the positive and the negative limits are the same. Can I have a diff magnitude for the positive and negative limits. Eg- can I have the waveform from -2 to +1?
Message 14 of 16
(862 Views)
You can add an offset like this.
Tim
GHSP
Message 15 of 16
(849 Views)
To get to -2 to 1 set the amplitude to -1.5 and offset to 0.5.
Tim
GHSP
Message 16 of 16
(847 Views)
