Can I run a labview 7 program using a newer version of Labview (14)?
I have a program running on windows XP. The program was wriiten and being run with Labview 7. How can I user a newer version of labview? Is this possible?
Message 1 of 8
(4,167 Views)
Hi Wrusso,
is this "program" an executable (created with LV7) or is it a VI running in the LV7 IDE?
If it is an exe: Do you have an installer (setup routine) to install it on your new computer?
If it is a VI: did you try to load it with your new LabVIEW version? (Don't forget to create a backup first!)
Message 2 of 8
(4,165 Views)
Hello, It's a VI (with many sub Vi's) created with LV7.
Message 3 of 8
(4,163 Views)
All (or most of it) should open just fine in LabVIEW 2015. Does it use any special drivers or toolkits?
Message 4 of 8
(4,153 Views)
Hope major changes happened after LV 7 till LV 2015 so it's better to convert your code to latest version.
NI Discussion forum itself has a separate place holder to convert one version of code into some other version.
You can share your code and get converted code back.
Message 5 of 8
(4,152 Views)
In this case, that will not help much.  Almost all we do is just mass compile it.  The OP can do that now.
The major issue I would expect is if any DAQ was involved.  Before LabVIEW 8, most DAQ applications were written with what is now called Traditional DAQ.  Traditional DAQ is not supplorted at all on Windows 7.  Unfortunately, there is not simple way to convert Traditional DAQ to use DAQmx.  An understanding of the VIs is needed and some rework will be necessary.
GCentral
Message 6 of 8
(4,135 Views)
Actually, it IS supported on WIndows Vista/7/8 but it requires a 32bit OS. It will not run on any 64bit OS.
(I recently had IT make me a 32bit Windows 7 PC so I can more easily load and convert the old code with traditional DAQ)
Message 7 of 8
(4,126 Views)
thank you
Message 8 of 8
(4,124 Views)
