Can LabVIEW be used on Cyclone V soc dev kit?
Hi
As topic asked,
If can, what do I need?
Reguards.
Alex
(974 Views)
Hi Alex,
after you successfully installed a current Windows version on your dev kit you can also install LabVIEW.
Is this what you are asking for?
When it comes to FPGA programming: NI software supports NI hardware…
(960 Views)
Sorry for my question let you confused.
What I meant is that if Labview can communicate with cyclone V soc board(which is the same board provided on this link:Cyclone® V SX SoC Development Kits (intel.com))
And how to communicate with HPS in baremetal environment.
(937 Views)
Hi Alex,
When that board offers a supported communication port&protocol you can surely communicate with it using LabVIEW as programming language...
You want to communicate with the CycloneV hard processor system?
Again: when it offers a supported port&protocol then you can communicate...
(935 Views)
Thank you for your fast response,
so is there any modules needed?
I was heard labview may need some kind of modules to communicate with some devices.
reguards.
Alex
(932 Views)
The HPS has one Ethernet and one UART interface. These are the most interesting you want to look at. For the Ethernet port you can use the built in network nodes to implement whatever protocols the HPS firmware supports. For the UART you would need to use the VISA nodes (and have NI-VISA installed).
What messages you need to send depends entirely on the firmware that runs on the HPS. That should be documented in the firmware documentation by the party who provides that firmware.
Rolf Kalbermatter
My Blog
(911 Views)
Heh, i read Cyclone B ...
Qestit Systems
Certified-LabVIEW-Developer
(902 Views)
