Can LabVIEW "read" Microsoft Windows Environment Variables?
I wrote a function that finds the value of an environment variable.
Do you think there is a better way? Sorry for the mess.
Same as you write in the cmd:
"echo My PC is %COMPUTERNAME% and user is %USERNAME%".
Message 41 of 44
(119 Views)
Of course there is a better solution, The windows API function ExpandEnvironmentStrings.
Message 42 of 44
(107 Views)
Hi Max,
Unfortunately you forgot to downconvert your VI. (I prefer LV2019, others may be happy with "LV2021 or older".)
In your image I don't see anything that reads the value of an environment variable. All you seem to do is to parse/format predefined strings…
Message 43 of 44
(86 Views)
I will have to look at the Windows API way that was mentioned. But the .NET API that I mentioned about 10 years ago in this thread is really the easiest and cleanest way to do it.
Message 44 of 44
(69 Views)
