Can any one pls help? convertion failure from labview 5 - 8
Here is a vi that I has been working on Labview 5, but as I open it with labview 8, I got a error msg like "bad connection or wrong terminal". So I checked the configuration of the vi in both version, but I didn't find any dissimilarity. Does anyone have any idea?
(2,477 Views)
I get the error "Visa Write: contains unwired or bad terminal". If you double-click on the error in the error list it will take you to the location of the problem.
In this particular case you don't have the "write buffer" input wired in one location (see image). Was there anything in the LabVIEW 5 version of the VI?
Message Edited by altenbach on 09-05-2006 04:08 PM
(2,474 Views)
me think there's a wire missing between "Write command string" & "write buffer  " input of the "visa write"
(2,408 Views)
