I am looking for an HMI/touch screen (~10" or larger) that will run LabVIEW/PDA on WinCE.
The TPC-2006 would be a fine solution IF the display was larger. A panel PC is out because we don't want to deal with all of the typical WinXP configuration maintenance issues.
The HMI must have at least 1 serial port and be Ethernet enabled.
Has anybody used one successfully with the PDA module?
