Can i optimize write of large data array into text file ?
I would caution that IIRC, parallelizing the For loop where you write your data can *NOT* be depended upon to write the data in the proper order.  The execution order of the parallel instances isn't prescribed and is probably unpredictable to mortals.
-Kevin P
<EDIT>  Dang, did it again.  Had a tab open to reply, didn't get around to it immediately, forgot to refresh before posting, found that I was just repeating what was already said.  Oh well, maybe two answers reinforces the point...
Message 21 of 23
(1,028 Views)
@altenbach wrote:
@mcduff wrote:
I did not know writing to an ASCII file could be done in parallel. Did you check that everything is written in the right order?
I would expect that the right order is not guaranteed using a parallel FOR loop.
Yes, definite oversight. Smiley Embarassed
The code is still slightly faster even without the parallelism.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 22 of 23
(1,024 Views)
Sorry, i've been a little busy these last days.
Thank you all for your answers and explanations. Your answers helped me a lot, and I was able to update my application and save time during its execution.
Message 23 of 23
(970 Views)
