Can't get my x-y plot to work correctly
Dennis,
You now know what i did wrong? Well, kind sir, do you plan to tell me?
Message 11 of 14
(734 Views)
You've been given the answer.
Message 12 of 14
(726 Views)
Accepted by jaydee1
And now with only 1 shift register Smiley Happy
XY graphs can be build up in two different ways:
a) 1 cluster containig 1 array for X data and 1 array for Y data. You can use this lay out when you get several, or all points, at one time or if you display the graph once you collected all the data.
b) 1 array of clusters, each cluster contains 1 X data point and 1 Y data point. You can use this lay out when you get one data point at a time and you want to display them immediately, not waiting to have them all.
I think the way you get XY data points fits the second way of working, so in the attached screenshot you can see that I make clusters of XY data and build them together using Build array and a shift register.
Message 13 of 14
(724 Views)
It seems like i get far quicker response here than in the other forum i posted another question. Guys, please see if any of you can help with the problem i described in the following link location: http://forums.ni.com/ni/board/message?board.id=280&message.id=6448#M6448.
The VIs are uploaded there. Thanks.
Message 14 of 14
(683 Views)
