03-08-2024 04:07 AM
I'm trying to install Labview runtime 2024 Q1 on a machine but it is currently not working. The package manager says:
Unable to locate package 'LabVIEW Runtime (64-bit) (>=24.1.1.49153-0+f1)' with a compatible version and architecture.
If I download the offline version from the webpage and try to install, it just says "No operation to be performed". I've tried on two different machines, both give the same error and both are running windows 10. I can install any other version fine, except the 2024 Q1 version.
What is causing this issue ?
03-08-2024 11:55 AM
I installed it last week on a machine with no issue. Now I try to install it and it doesn't work. Have you found the issue?
03-19-2024 03:10 AM
I haven't tried using the package manager again, but I contacted support and they sent me the file directly, which worked
03-19-2024 10:07 AM
There likely was an intermittent problem that's been fixed - it should be working now.
08-07-2024 03:35 AM
I'm having issues with this - from the package installer I get
regards AA
08-07-2024 08:49 AM - edited 08-07-2024 08:56 AM
I know I can open a support request for this, but I need a quick solution (bit in a rush here). So I'm asking here, in case someone faced this and have aleady a solution.
I've downloaded the LabVIEW 2024 Q3 installer from the ni.com download page. When I run the installer on a fresh Windows installation, after the NI Pacakage Maganer is installed, I get this error:
Clicking the Cancel button, of course, stops the installation process, so I can't install LV 20204 Q3.
I've tried on other systems this morning to install LV directly through the Product page of the NI Package Manager and got the same error.
08-07-2024 01:33 PM
I think the ni.com package repository was having some issues this morning, but they should be fixed now. Please give it another try.
